Just found this forum
Anyways, I realized I should rename this thread and move it to the "member's builds" section. Any way to do that?
You've only got a few posts in this thread that are about your build. Just start a new thread over in the other section so it will be a "clean" build thread. As if it will stay focused. Gotta try.
Here's an example of how the modifications snowball. Since I'm old, I decided to add aftermarket A/C. I felt like having an electric fan on the condenser was a must. No room to put a puller fan behind condenser, radiator is in the way. Pusher fan in front of condenser hits hood latch crossbrace. Solution: trim crossbrace (which means I'll have to weld in some thicker support metal for strength), move condenser back 1/2" (which means I have to build new condenser brackets, and alter/fab A/C lines to fit ), mount pusher fan on front (build new fan mounts).
View attachment 30053 View attachment 30054
this kind of stuff is exactly why my 67 has no AC. I have a pusher fan and a mechanical/belt driven fan with shroud and it's all it can do to keep the 429 cool in traffic.
Took Horseplay's advice and started a new thread in the Member's Builds section, so I'll continue posting my progress there...
