Re-restoration in progress for some vintage racing
Milled down the ends .125" and now it lines up with the head ports perfectly. Re-checked the valve lash too.
If only I could have been here to assemble it the first time.
Did have to go find a different set of intake gaskets. The Felpro 1250S3 DO NOT fit 289 heads! It leaves the outside edge of the water ports exposed!
1262's
Vs 1250S3
Vs overlapped
if only you knew someone who could have told you the correct gasket to use in the first place. :rolleyes: Putz
Just JB weld the head on. No need to worry about leaks then.
lol Please, nobody actually do that.
You actually use the turn signal lever while racing???
I like your dash cluster, but have a few questions. What's the large orange or amber light for? No volt-meter? You actually expect to run at 7500 rpms as your normal racing speed?
Lever is a holdover from street duty. It'll be gone.
Amber/yellow/orange...whatever is for high water temp. Comes on at 225*. Just added that one.
No volt meter.
7500 is max rpms before chip kicks in. The motor was made to spin 8k.
