How-To Section
All when you click on the link above Resources you should see this page
Can you see the ADD RESOURCE on the right?
I'm fairly new here, soooo...what changed between May 4 and today to prompt the start the Resources forum? Also, when I click on the link you provided, I get a message saying I don't have proper permission to view the content of the thread... because or something to that extent.
Drinking heavily last night and played around on the CPU...:)
Yes we, or at least I...can see the thread, but that's where it stops. There is a message at the bottom of the image that says something to the affect of not having privileges to view the full content of the thread.
@Patrick Stapler just tested it using the Test Permissions and it works
"The permission tester allows you to view the forum with the permissions of the specified user. You will still be logged in as yourself, but your permissions will show you what is visible for this user."
I just added a "resource" a bit confusing process that doesn't seam to work right. I just ended up putting a description in the text and a link to the original in the description as well. can you guys see it?
I can see yours but the other two has the following
"You do not have permission to view the full content of this resource."
it's a bit confusing when adding a "resource". There are places to put URL's. Maybe the links are to places we don't have permission to go?
No more issues with needing to log-in or limited ability to read the entire thread from here.
