Re-restoration in progress for some vintage racing
I'm surprised "stock" stamped covers clear your rocker set-up. And I forgot what you are doing with your vent set-up. You can't run a draft tube, right? Are you using a "catch can" type arrangement?
Yes, catch can as required. Same as before.
How come ?
Bad experience ?
Fram is a brand thats on the market for years.
I have bought Wix, Hastings, Amsoil and Fram filters and cut them all apart. Fram's filtration and construction is significantly weaker. The # of pleats in the Fram are much less and less dense than the others I have referenced.
It is so pretty....it will be a shame to see it blow up like so many have in the past at the hands of {.}
