1965 Fastback restomod
Left side trunk floor welded to the rear frame rail
New rear panel with package tray test fitted and also the quarters and taillight panel installed before the rear crossmember is welded. We wanted to make sure everything lines up in the rear before the rear crossmember is installed.
Rear crossmember welded to the trunk floor and rear frame rail
Rear trunk floor prepped for epoxy primer
Epoxy primed
How do you guys great ready for the epoxy? The same grit roloc you use for grinding, a higher (numerical) grit (finer) roloc? A DA?
Brian started patching the right quarter and roof inner structure
The outer structure was removed so he can repair the rust under it.
Brian made the first patch
Brian made a few patches than cleaned everything and epoxy primed
Starting to put the puzzle back together
As Frank Barone would say "Holy Crap" That is nice work!
Looking forward to more updates...
I'm still trying to decide if I'm up to removing the roof on mine. After seeing what is doing under the roof on this one, I'm thinking maybe I should go for it.
Wish I had Brian's skills, then I wouldn't be as terrified as I know I'm not up to removing the existing skin without ruining it, and if the repro roof doesn't fit right, then I'm up the proverbial creek without a paddle...
Super work! Brian has some super metal working skills that I'm in awe of! :thu :thu
Thanks to the pics posted of his rebuilding the upper corner of the windshield opening it helped me out immensely in laying out and rebuilding the same area on my coupe project! Keep those pics coming, can't wait to see the car done! :yah
Brian has to make or patch the inner structure since it is not available.
Next epoxy before making another patch
Since you cannot get this Brian had to patch the original
Brian is replacing part of the left outer rocker
This is what was inside
He also cut a hole in the front so it could be cleaned out and epoxy primed
Brian replaced the left rocker
Starting to repair the left quarter panel inner structure
Test fitting the sheetmetal before welding in the rear package tray panel
Rear panel is welded
Marking the area that needs to be cut out for the Graverobber wheel wells
