1966 Mustang Coupe Restomod
Discussion in 'Member's Build Threads' started by GPR, Apr 15, 2015.
  1. Ponyman66
    Ponyman66 Yak, yak, yak
    WOW! That's lookin' GREAT Rusty!!
  2. GPR
    GPR Active Member
    Brian has the sheetmetal lined up.
    [​IMG]
    Test fitting the new Stang-Aholics front valance
    [​IMG]
    [​IMG]
    The gas filler will have to be moved down a little because the cap hits the deck lid.
    [​IMG]
    Grabber70Mach likes this.
  3. RapidRabbit
    RapidRabbit Well-Known Member
    Wow! Nice work.
  4. Mach1Mark
    The wheel flares look sharp !!
  5. Grabber70Mach
    Looking really nice
  6. GPR
    GPR Active Member
    I have been busy working in the shop and I need to update
    I block sanded the fiberglass hood
    [​IMG]
    Sprayed one coat of SPI black epoxy
    [​IMG]
    Two Coats of SPI Turbo primer
    [​IMG]
    Block sanded again
    [​IMG]
    Two coats of SPI epoxy
    [​IMG]
    The fiberglass bumper did not fit our car. The center section did not line up with the lower valance and the bumper was to narrow.
    I cut the center out of the bumper and had to modify the holes in the taillight panel to get the bumper lowered.
    [​IMG]
    I used Duraglass to attach the brackets to the bumper. Later I added a couple layers of fiberglass to hold them in place
    [​IMG]
    This shows you have much I need to add to the left side
    [​IMG]
    I added fiberglass to the top to hold it in place
    [​IMG]
    I clamped it to a long piece of angle and added fiberglass on the back side.
    [​IMG]
    I removed the braces and clamps and finished adding fiberglass to both sides and this is how it looks now. I still have to work on the gaps.
    [​IMG]
    [​IMG]
  7. Fast68back
    Fast68back Well-Known Member Staff Member Moderator
    I think the bumper looked great in the first picture where it was two pieces, you should have raised the license plate up to mount between them. Still awesome work!
  8. GPR
    GPR Active Member
    I epoxy primed the bumper and test fit
    [​IMG]
    [​IMG]
    It still needed a little bodywork
    [​IMG]
    Epoxy primed again
    [​IMG]
  9. GPR
    GPR Active Member
    This project will be on hold for a little while.
    [​IMG]
    [​IMG]
  10. Grabber70Mach
    It's looking really good, keep us updated when you get back to it.
  11. GPR
    GPR Active Member
    We are back working on this project. I had to do a little bodywork on the front of the fenders to get them to line up to the new front valance and epoxy primed.
    [​IMG]
    Front valance and rear bumper block sanded and epoxy primed
    [​IMG]
    [​IMG]
    Test fitting one more time
    [​IMG]
    [​IMG]
    Mach1Mark and Grabber70Mach like this.
  12. Fast68back
    This thing is sharp!
  13. GPR
    GPR Active Member
    We have been working on this doing a lot of little things to make it look right. The hood did not line up with the headlight buckets so I had to add fiberglass to the end of the hood.
    Brian test fit all the door glass, vent windows, quarter windows, windshield and back glass moldings
    This area needed a little work
    I worked on the body lines
    As you can see in this photo the front valance was a little high and the fender had a low spot that needed bodywork
    In the middle of a lot of block sanding and looking for any imperfections
  14. Fast68back
    Great build!
  15. Grabber70Mach
    You all do fantastic looking work.
  16. GPR
    GPR Active Member
    The back of the hood was sanded and epoxy primed
    Block sanded the body and epoxy primed
    The trunk was sanded and epoxy primed
    The engine compartment was sanded and epoxy primed
  17. GPR
    GPR Active Member
    Test fitting the Stang-Aholics upper and lower grille
  18. Grabber70Mach
    That's going to look nice.
  19. guruatbol
    guruatbol Always on vacation!
    You know I wasn't sure how I felt about the shaved drip rails. After seeing it with paint, I like it. One less rust spot.
  20. Fast68back
    What color will it be?
