1967 Build called Electra
Discussion in 'Member's Build Threads' started by JRANGER, Mar 12, 2013.
  1. JRANGER
    JRANGER Active Member
    Wanted to start a thread for everyone to follow as I build my mustang.
    Shes a 1967 Mustang Coupe that originally had a 200 Ci 4 lug with 3.20 gears in it. Stock painted Gold, Manufactored in Deaborn MI requested district from New Orleans, and built October 18th 1967. It was originally restored in 2000 using Candy apple red and at some point converted to a 302 engine, 5 lug with 8" rear end with 2.80 gears . She runs strong is pretty straight, and just needs some TLC and upgrades.
    I want this to just be a cruiser but have some more modern drivability
    My Plans:
    Remove the small amounts of rust.
    Upgrade to front disc brakes
    Upgrade the Power Assist steering to isuzu steering (Maybe)
    Upgrade the rear end gears
    Paint (Charcoal or Blitz Black)
    Tires
    Upgrade the suspension
    Needs carpet and Dynamat
    Clean up electrical problems (Passenger side lights are dim)
    Upgrade lighting with H4 Bulb setup and Relay Harness
    Eventually maybe upgrade to a T5 (Not an immediate need)
    Upgrade the stereo equipment as it has blown speakers in the rear
    Reupholster the High Back Buckets to Leather or Vinyl (Red and black interior)
  2. JRANGER
    trying toadd more but reply isnt work erg
  3. tarafied1
    tarafied1 Well-Known Member
    you can actually start a gallery here on the fix if it's easier....
  4. janschutz
    janschutz Corn Hauler
    Great! Glad to see more 67 - 68 coupes being restored. Keep posting!
  5. JRANGER
    Today I wire wheeled the trunk and found a few small holes so i welded those up and then coated the trunk with POR-15. Only 1 coat so far
    Also wire wheeled the passenger side floor pan...It has a bunch of small holes so i may cut it out and replace the whole floor pan
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  6. tarafied1
    looking good, that's a lot of work!
  7. JRANGER
    na, it didnt take long at all! Just a couple hours
  8. crustycurmudgeon
    crustycurmudgeon Well-Known Member
    Had to have been 1966 for a '67 model. October 18, 1967 would have been a 1968, if Ford hadn't been on strike in October 1967.
    Good luck with your plans, and welcome to Stangfix.
  9. tarafied1
    When would they have changed over? Mine was built 7/7/67...
  10. SELLERSRODSHOP
    SELLERSRODSHOP Active Member
    you car is exactly one yr older than me. :hide
  11. Anonymous
    Anonymous Guest
    Whippersnapper.
  12. JRANGER
    Well a little more work today...The POR-15 dried and looked horrible because its gloss black but that didnt matter anyway since its not UV protected. I scuffed it up and put 3 coats of Dupli Color Bed Armour on it. Ill take pics and post them up in a bit when it drys out some.
  13. JRANGER
    Still not completely dry but the matte finish of Bed Liner is much nicer then gloss black. With a quart of POR-15 and 3 Coats of Bed Armour im pretty sure the trunk will hold up lol
    [​IMG]
    [​IMG]
  14. JRANGER
    Bought a few small things from CJPONYPARTS
    Long Passenger Side Floor Panel Patch
    Oil Sender Switch Gauge Style 1965-1989 - This says if i have the stock wiring ill need an adapter so i assume i dont have stock wiring...But ill find out
    Temperature Sending Unit 9/1/1965-1995
    Trunk Weatherstrip Coupe/Convertible 1965-1970
    Scott Drake Manual Shifter Boot Upper 1965-1968
    Hood To Cowl Seal 1967-1968
    Manual Shift Screw 4 Black (Hope this is for the boot attachment)
    __________________
  15. tarafied1
    progress!
  16. tarafied1
    cool, so when you bought me lunch on my b-day yours was just a few days after? :char
  17. SELLERSRODSHOP
    Yep falls on 7-7
    Sent from my iPhone using Tapatalk. That makes me special!
  18. JRANGER
    Well nothing to report on the mustang but me and a bunch of truck buddies get together monthly to work on our old school chevy/gmc trucks. Today was our good buddy Rus's work day. We managed to tear down the front clip on one of the trucks he is working on and dissembled the frame for his bagged dually build Unfortunately i might of did a lil too much as my knee swelled up and i had to leave early but live and learn. Hope everyone is having a good weekend
  19. tarafied1
    cool, do you have an old chebbie truck?
  20. SELLERSRODSHOP
    i can verify, he had it at my house today :thu
