1967 Fastback converting to Electric Fans / Carburetor fuel boiling
Discussion in 'General Mustang Discussion' started by 67stang, Jul 16, 2018.
  1. Horseplay
    There is a fair amount of personal preference for which way to go as either can likely meet the need. A couple thoughts. If you go electric as a replacement for the stock mechanical it is likely going to be loud due to the size required. I am currently set up this way and while it works I hate the way it sounds outside the car. You hear as much fan as you do engine.
    Since your current set-up works well up until you get stuck idling for a while the addition of a pusher in front of the radiator might be a better option. It can be wired through a sensor to only turn on as needed when the car gets too hot.
    You might also think about simply trying the high volume 6 bladed mech fan too.
  2. 67stang
    67stang Active Member
    Does anyone ever put the pusher in front of the AIR Conditioner evaporator?
    Also any recommendations on pushers?
  3. 67stang
    Well if I go with the 2500cfm puller fan and shroud which requires (see below). I assume I should use a 180f thermostat?
    I did a little research and it seems carbs need to fun just a tad lower the EFI’s?
    [​IMG]
  4. 67stang
    Well I’m going to try everything!!
    Plan A:
    First:
    I will keep the mechanical fan and insert a 14 inch 1200cfm in front of the AC condenser. I will test it and see if that works.
    Plan B:
    If that does not work then I will remove the mechanical fan and replace it with the 16 aluminum shroud puller fan.
    I will keep you guys posted!!
  5. Midlife
    Before you go to the electric fan, have you installed the phenolic spacer yet? That single and cheap item will be the most helpful to keep your fuel from boiling.
    Grabber70Mach and tarafied1 like this.
  6. tarafied1
    tarafied1 Well-Known Member
    agreed, that should be first
    Grabber70Mach likes this.
  7. Horseplay
    He's battling a couple issues at once in this thread. The focus right now (most recent posts) is trying to keep the car from overheating.
  8. tarafied1
    good point but I'd still go with the spacer. It's cheap and easy... (I'll just leave that wording right there).
  9. Midlife
    I beg to differ. His post (#4) states:
    "I have an old style gauge for temp (no numbers). It’s does seem to work. And if I’m idling it never has reached the middle. At most maybe 40%, but normal around 30% then when I start driving it will go down near C. During cruise (as expected) always at c."
    To me, this is perfectly acceptable gauge response. No mention of coolant overflow or excessive temperatures, although it would be nice not to have the gauge creep up at idle.
    Re-reading the thread, he said that the phenolic spacer is 1" thick and is concerned about the carb hitting the hood, so he's going to this quick cool spacer that is only 1/2 thick. I'm not sure how much effect it will have, other than draining his wallet...
  10. 67stang
    Since I had the quick fuel carb, I went ahead and installed the cool plate, which is a sandwich of about 1/2. I could do another 1/4.
    [​IMG]
  11. Horseplay
    Try scanning the last couple pages the talk of engine heat progressed further from the initial question and suggestions. He's provided a lot more info including actual temp readings. Come on, man!
  12. 67stang
    Ya, I did overpay on the phenolic spacer. Pretty interesting concept though, the inner material is strange. But anyways there is a drop in temp. But I should have used the temp gun before I installed the cool plate so I could see what the difference really is.
    O well.
    So yes my investigation has led to the topic of over heating, which I hope to fix in the coming weeks. The electric fan won’t be here till week.
    Stay tuned!!
  13. 67stang
    Update 1-
    A- New thermostat 180.
    B- Front spal fan 11 inches was the biggest that would fit :(.
    Results: It will hold around 217.
    Summary: So the good news it does seem to help. That bad news not enough!
    Tomorrow I will try to install the puller fan and I think I will also keep the pusher.
    [​IMG]
  14. tarafied1
    I imagine the 11" is just not big enough but I understand the clearance issues!
  15. B67FSTB
    I see you have an A/C condensor in front ???
    You should seal the condensor to the radiator so you don't loose airflow.(exspecially when using a pusher)
    A "sucker" iow "puller" is way more efficient ! Keep that in mind .:p
  16. 69bosssvt
    69bosssvt New Member
    So... I just read your thread and have, in the past, experienced similar problems with a 67 with a 351w. What I/we don't know is:
    How fresh is the engine rebuild?
    Did you have the work done?
    If and how much the cylinders have been bored...
    I chased overheating for 2 summers only to find out that the engine builder bored the engine .060 over and didn't let the previous owner know. I ended up having to start with a fresh block, and you know the rest.
    I know nothing about your engine, but that's what happened to me...
  17. 67stang
    UPDATE 2
    Great news.
    I installed the puller without the shroud, because to properly install this set up the fan needs to be on the outside of the shroud to create a suction. Problem is I don’t have enough room.
    So I just strapped the puller and pusher just to test.
    Results:
    I ran my car to a temperature of 210 with the fans off then I manually turned on both fans.
    Within 1-min the temp dropped to 195.
    I idled it For 10 minutes!!! In 90 degree fl weather in the garage with the hood closed and averaged around 188 and 195.
    So stoked!!
    However I will return the fan and shroud (overpaid Cj poney kit). and purchase a high volume Spal 16 inch puller.
    So I will be down for a week or so.
    But in the mean time I will permanently install the pusher.
    I might even make my own shroud that is 1/2 inch away from the radiator to create a suction and mount the puller to the outside. We will see.
    [​IMG]
    69bosssvt likes this.
  18. Horseplay
    Nice. A thought to consider and monitor. That will be a lot of juice being used to power both fans. Make sure your alternator is up to the task.
  19. 67stang
    I have a new 100 amp alternator. Hopefully that’s big enough.
  20. 67stang
    Small Update:
    I permanently installed the pusher. I hooked it up to the compressor so it’s comes on when the AC is on.
    [​IMG]
