tarafied1
We bought our son a fabricated valve cover for his Bobcat for Christmas. I helped him install it yesterday/today. We ran into many issues. First, the valve cover is much wider. The Holley was already pretty close to the stock VC. So we got an adapter to turn the carb sideways. That required some fabrication of throttle linkage but that moved the carb sufficiently out of the way. The new VC didn't have a provision for the PCV so we drilled a hole and put a grommet in there but without a baffle it sucked oil into the intake and smoked a lot. So we bought a push-in breather to act as a baffle. That worked. We have also been trying to chase down and oil leak. I think we found it. Front cam seal that the machine shop installed doesn't appear to be a tight fit on the cam. So we are waiting for a new seal!
