1999 Mustang GT
jmelmore5
New Member
Put a new engine in my 1999 mustang GT 4.6L after driving for a couple week it will not run. My odometer reads dashes and I am getting no fuel. If I squirt starter fluid in throttle body it will start it just will not stay running.
Sent from my SM-N910V using Tapatalk
I have a few thoughts.
1. make sure your inertia switch is good.
2. Have some one lay at the back of the car, turn ignition to the run position and you should hear the pump run until pressure is achieved. They are known to go bad.
3. Fuel filter clogged.
From Infinity and beyond
Never Argue With A Moron– They Will Drag You Down To Their Level, Then Beat You With Experience
I was thinking fuel pump or relay. Thanks I will try this. Still not understanding the odometer reading just dashes.
