351W and test stand
Discussion in 'Engine and Drivetrain/Mechanical' started by B67FSTB, May 29, 2018.
  1. B67FSTB
    I recently bought an 351W engine from someone who has a 69 cougar XR7.
    I was some kind of cheap depends on how you approch such a buy.
    I needed an engine for my 67 fastback which I bought in Germany.The car was totaled but I see potential in that car because its restorable.
    I didn't hear the engine running but removed the valve covers and it is clean.
    Some exhaust valves were black/wet from oil dripping through the valve guide I presume.
    Later at my place , I noticed that the RH head gasket was mounted falsely. Tab of the gasket was visible at the rear of the engine instead of the front side.Also the exhaust valve of cyl 4 was kind of white/yellow which indicates heat , I guess.
    So I am planning to test run the engine first.
    Because I am on a budget , I scrap everything together what I had laying around at my place.
    I have alot of square tubbing 1 1/2 laying around to make a chassis for the test stand.
    Some things were bought new , 2 of the 4 wheels , some nut and bolts , some sheetmetal.
    I had a alu radiator net so I bought some alu sheetmetal and let it bent into a U-shape profile.
    After some cutting and bending I made the upper and lower collector of the rad which will be mounted on the test stand.
    Here are the pics. BTW I got my inspiration on YouTube channel. Thanks to those guys !!
    tarafied1 and Grabber70Mach like this.
  2. B67FSTB
    the rad.
    Grabber70Mach likes this.
  3. Mach1 Driver
    Mach1 Driver Active Member
    Nice build, I was thinking of making one out of lumber and using the old radiator, etc. for the new engine break-in, then disassemble the kludge to get it out of the way. You've got a valuable piece of equipment there.
  4. Horseplay
    Nice job! Looks well built. I would advise including a rear mounting fixture for the engine too. Even just a single strut welded to the frame that has a tab to bolt into a bellhousing location, for example. Would make it much more stable when running.
  5. Caper50
    Caper50 New Member
    Nice job. Once I no longer needed my body cart I cut it up and built a test stand too. Now that my engine is back in the car a friend borrowed it to test a 302 for his 66.
    [​IMG]
    [​IMG]
  6. Grabber70Mach
    Looks good, you did a really good job on it.
    _____________________________
    Never argue with a Moron. They'll just drag you down to their level and beat you with experience.
  7. B67FSTB
    Thx guys !
    Yep , I know. Project isn't finished yet. Looking for a nice construction strut set up. ( so I can show of!!).
    BTW , right now the engine has a good front/rear balance.
    Right now I am waiting for some alu tubes to finishe the rad.
    Also still busy to look for electrical parts , like wires , relays ect.
  8. B67FSTB
    some more pics
  9. Horseplay
    That's pretty sweet, Bruno! Well done.
  10. B67FSTB
    Made the shroud and mounted the fan.
  11. 3175375
    3175375 Well-Known Member
    You should drill holes in the sheet aluminum outside of the fan to get more air flow
  12. Horseplay
    If mounted in a car those holes you see in some shroud set-ups are to prevent excess pressure build-up in extreme cases. For this purpose, they are not needed. The fan is the only thing causing air movement.
  13. B67FSTB
    Correct. In cars they usually have flaps so when pressure built (due to excessive driving) the flaps will open and when the fan kick in , the underpressure ( between rad and shroud) will close the flaps and cooling is forced by the fan.
    Yesterday i got my hedman headers. Nothing special , plain painted iron headers.
    I also used a 64-66 battery tray , drilled out the spotwelds from the support , mounted it on the frame.
    Pics will follow.
