A few questions regarding a motor i just picked up its a 94/5 ish 351w roller motor had fuel inj on from a f250 pick up i think.
1.i want to fit this into my 67 with carb set up my concerns are will the dipstick which comes out of the block at drivers side interfere with headers on a 67?
2. what grind roller cam can i fit using the existing heads,for fast street use
3.i want to fit a double roller timing chain and use a mechanical fuel pump will the pump cam rub against the timing cover?
4. can i fit standard 67/70 pulleys on and what yr water pump should i use
