monkeystash
I bought this car October 2004, originally planning to turn it after a quick restoration. I was definitely in over my head. I eventually became attached to it and decided to keep it. The PO was a complete hack and all his bodywork had to be redone. This car was bought off ebay, and I drug it home from Oklahoma City, 2000 miles round trip.
My plans are for it to be stock appearing, but modern under the skin. The exterior will beWimbledon WhiteCandy Apple Red, and the interior will be black standard. The drivetrain will be a 408W backed by a G-Force T-5 and Currie 9". Suspension will be Maier leafs and panhard out back, and TCP arms up front. Baer 13" PBR brakes in the front and Mustang Cobra brakes for the rear. Here's some parts porn:
Here is the day my Dad and I picked it up:
I now had a good excuse to buy a big compressor and a welder:
I started to tear it apart. San Jose built, DSO'd Oklahoma City where it spent it's entire life. The rails and cowl are in great shape:
First thing to tackle was the battery apron:
I ended up sandblasting the engine compartment after I put in the new battery apron:
I painted the engine compartment. Looking back, I should have waited, as I'll most likely have to redo it:
Here's the engine that came out. It's a 66 289, so not the original one.
I had to rip off the repro quarter skins the PO installed, and installed new ones. It also need a partial passenger side outer rocker due to damage, not rust:
TCP subframe connectors installed:
Taillight panel was full of bondo, so I cut it out:
I stripped the underside with a 36 grit 3" roloc. Definitely not the best tool for the job, but it worked:
Front torque boxes installed too:
Although hard to see in the picture, the roof is lumpy as hell. I have a good original skin lined up and it will most likely be replaced.
Seats recovered and ready to go:
This is how it sits today, March 2010. That is 5.5 years after I brought it home.
