The time has come for me and my '66 to part ways. It's been a fantastic car, which I've now owned for 12 years, and built myself over those years. It was my daily driver from '98 until '07 or so. Since then, I joined a car pool and the car has been driven extremely little (if I'm driving one, it's the '69 with the 408/TKO-600).
This car is has zero rust, and has been garaged for all the years I've owned it. It has all the original floor pans, engine bay panels, quarter panels, and the trunk. No patches at all, anywhere. I have well over $25K in parts alone in this car, and receipts for every single one. The paint is a 2 stage BC/CC paint job, called "metallic pewter". It is about 3 years old, but does have a couple small chips in it. This car is ready to go drive and enjoy right now. It really needs nothing. 99.9% of all wiring in this car has been replaced with new wiring. The only parts I can think of that have not been replaced is the wiper motor and it's wiring harness, the turn signal switch, and the wiring harness from the dash to the trunk.
This car has run a best time of 14.003 in the 1/4 mile with the old cam in it, and on the existing street tires. It has not been to the track with the current cam, which has about 2k miles on it, and is quite a bit more aggressive than the old cam. With some sticky tires it should be running in the low 13's (just needs more traction to get there). On the freeway, it can get 20+ mpg with the overdrive transmission (Ford AOD transmission), even with the 3.50:1 rear gears.
I'll be straight up with StangFix members. I will take $12k for this car, but that price is not negotiable. The following list shows the bulk of the parts that have gone into this car, so you can see the beating I'm actually taking. I will help arrange shipping. I will not trade, though, and won't go below the $12k (this is a special StangFix members deal only). It is going to be advertised, simultaneously, on Craig's List for $15k.
These are not old pictures. They were all taken today, 6/1/2010.
ENGINE
Fuel Delivery
Exhaust
Ignition
Drive Train
Suspension/Brakes
Interior
Other
ENGINE
- 289 CID, rebuilt and balanced. Has 66k miles on it.
- KB pistons, bored .030 over. 10:1 compress ratio
- '69 351w heads (with 10:1 pistons, ends up with about 9.3:1 end compression ratio and runs great on 93 octane)
- Edelbrock Perfomer RPM intake
- Edelbrock Hi-flow water pump
- Comp. Cams Extreme Energy XE262H cam (Duration 262/270, Lift .493/.500)
- Harland Sharp roller rockers (with screw-in studs and guide plates)
- Double roller Ford Racing timing chain
- Griffin aluminum radiator
- SPAL 16" straight blade electric fan
- PowerMaster 100 amp single-wire alternator (w/ original Voltage Regulator removed)
- March pullies for alternator and water pump
Fuel Delivery
- Holley Red Barrel electric fuel pump (with hidden kill switch in interior)
- Edelbrock 1405 carburetor, re-jetted and calibrated. Electric choke added
- 1/2" phenolic carb spacer.
- K&N performance air filter
Exhaust
- Flowtech Terminator, full length, ceramic coated headers w/3" collectors
- 2.25" dual exhaust with H-pipe
- Dynomax Super Turbo Mufflers
Ignition
- MSD 6-AL capacitive discharge unit
- MSD Blaster II coil
- MSD Pro-billet distributor
- MSD 8 mm custom made wires
Drive Train
- AOD transmission
- B&M 2400 HoleShot stall converter
- B&M TransPack shift kit
- 9" Traction-Lok in original '66 K code Mustang housing.
- 3.50:1 gears
- B&M external transmission cooler (in addtion to in-radiator cooller)
Suspension/Brakes
- OpenTracker Racing roller spring perches
- OpenTracker Racing roller upper control arms
- Street Or Track adjustable, rollerized strut rods
- vario-centric camber kit (eliminates '65/'66 front shims)
- 1" Aadco front sway bar
- Monte Carlo bar
- Export Brace
- 620# front springs, lowered 1"
- 4.5 leaf Grab-A-Track mid-eye rear leaf springs
- KYB GasAjust shocks
- All rubber has been eliminated from front suspension & replaced with rollerized parts with bearings
- '70 Mustang front disk brakes
- '74 Maverick manual disk/drum Master cylinder (feels like power brakes without the booster)
- Manual steering with quick ratio steering box
Interior
- Corbeau sport seats
- Alpine AM/FM/CD with IPOD hook up in the console (controlled from head unit)
- Autometer gauges under dash for voltage, oil pressure and temperature
- Grant Signature steering wheel
- T-Lock, locking shifter handle for security
Other
- Fully automatic electric antenna re-located to right rear quarter panel
- Mustang Project sequential tail lights
- 15x7 American Racing Torque-Thrust D's
- 205/60/15 Yokahama front tires
- 225/60/15 Yokahama rear tires
- Body colored drip rail moldings
- Fog lights added to front grill, but have never been hooked up or used.
