67 oirg factory pwr disc brake car.
Your opinions on if I should:
Rebuild and use the orig proportioning valve that is located at the back of the car
or
Install an adjustable proportioning valve and add a short section of line at the rear to replace the orig valve and add the tubing needed to route through the adj prop valve.
Basically, if the factory prop valve is set right for the factory disc/drum setup is it worth the work and part to add an adj prop valve under the hood that will likely rarely if ever be adjusted? Is the factory setting on the orig type valve not really the ideal bias anyway?
or
