RagTop
Old Grumpy
I'm still screwing around with replacing the dash light bulbs and voltage regulator on my 69 vert while I've got the dash pad off the car. I just tried to pull the cluster forward and I realized that the wiring and the speedo cable seem to have it pinned. It moves forward less than 1" before reaching the extent of the slack in the connections. The official Ford shop manual says to disconnect the plug from the harness to the PC board and to disconnect the speedo cable by depressing the tab on the side of the connector and thence remove the cluster. Well, I can't get the cluster far enough forward to fit my meat hooks behind it to pull said connections. Also, I'm guessing that the factory plug to the PC board is a locking type that requires the depression of some sort of detent clip to separate it. Does anyone here have any apriori knowledge of removing this thing? I find that a little course knowledge serves better than a ream of vague manuals. Help!
