70mm throttle body NEW
c6fastback
Brand new Edelbrock throttle body ...IN THE BOX ....yeah it's for Honda /Acura :rant
Asking $270 shipped or OFFERS considered ......
Can email pics if needed .
Mike
http://www.edelbrock.com/sportcompact_new/mc/throttle_bodies/tb_vict.shtml
VICTOR X THROTTLE BODIES
HONDA/ACURA 70-75mm THROTTLE BODIES
Victor 70mm and 75mm race throttle bodies can be easily adapted to a wide variety of applications. We eliminated the idle air motor mount and all unnecessary vacuum tubes, making these throttle bodies especially well suited for racing applications. The throttle arm has a cable wheel with multiple take-off points. They are cast and fully machined by Edelbrock, then assembled by Magneti-Marelli USA. Shipped complete and ready to run with a throttle position sensor installed and pre-set, these throttle bodies can be adapted to a number of applications using our 1/2" thick spacer/adapters. Intake port matching may be required in some cases. Spacer/Adapter kit required for mounting to manifolds with stock throttle body bolt pattern.
VICTOR X THROTTLE BODIES FEATURE:
Brand new throttle position sensor is factory installed.
TPS is pre-calibrated with the same type of high-tech machinery used by OE-manufacturers.
Edelbrock is the only aftermarket manufacturer that includes a new TPS sensor.
Assembled by Magneti-Marelli USA, a major manufacturer of OE throttle bodies.
Cast & machined by Edelbrock in their QS9000 certified factory... QS9000 is required by OE-manufacturers to ensure maximum quality control.
Sealed ball bearings used in the throttle shaft for smooth, dependable operation.
