Indycanard
Well, after a couple weeks installing a Sanden type compressor with condenser, I have a leak. It took FOREVER to drill the two 1-1/4 holes thru the radiator support AND the two 1-1/4 holes thru the firewall. I burned out 3 cheap Harbor freight hole saws. I finally got a good quality bi-metal hole saw, and the metal cut like butter on the last hole. Anyway, I installed all the hoses, and tightened up all the joints. I connected my A/C manifold gauge set and sucked the air out with my vacuum pump. I could tell the pump never really got the air all out. I have a leak somewhere. With the pump closed off, the vacuum bled out after 120 seconds, may a little more than that.
I really would like to have a sealed system and sucked out for a couple hours if possible. I can find a leak once pressurized with the leak dye in the freon, and I have a black light. Is there anyway to find a vacuum leak? I guess I could pressurize with a little freon just to leak check, then evacuate again to get all the moisture out.
Any ideas?
Any ideas?
