A4LD transmission ???
tarafied1
My oldest son has been driving the 93 LX since he hasn't got his 79 running yet. He's been driving it a few months. He said recently the trans acted like it would not shift unless you ran it up in rpm, then let off. Then yesterday he called me and said "I think it's done" the car won't move and makes a horrible grinding noise from the trans.
Anybody know much about the A4LD? I did a little research on the interweb. There is a possibility that the torque converter failed.
I towed it home, I will begin to remove it and check it out.
yep.
I know I should be but it is so nice to be home, there is so much to do! I fixed the lawn tractor today. Been starting it with a screwdriver as the solenoid was bad. Now it starts like a yuppie mower!
I got the 93 into the garage so I can start taking it apart. Kitchen is almost done....
Well, the low/reverse planetary is toast!
