Any Excel programmers out there?
Discussion in 'Non Mustang General Discussion' started by FordDude, Apr 26, 2017.
  1. FordDude
    FordDude Well-Known Dude Staff Member Moderator
    I am a novice with excel programming. I can do simple things. But the formula I need to use is going to look like an algebra formula from my high school days 40+ years ago.
    Simply put 4 columns, first being the store number then the city and address. I want the store numbers to be in numeral order no matter how I enter them. So the entire row needs to shift position. Anyone?
    Just for looking here is a playboy playmate waiting for you...
  2. msell66
    Do you have the ss already made?
  3. Jonk67
    Jonk67 Well-Known Member
    Can't you just add a filter to all 4 columns and turn the first column filter to sort smallest to largest? The filter has to be at the top row of all 4 to keep the info together for each store.
    Sent from my XT1053 using Tapatalk
  4. stangg
    stangg Member
    I tweaked a little code via google search... This immediately sorts column A as soon as you enter a value into column A.
    Maybe this will get you started. Drop this code into "Sheet 1" using the VBA Project editor.
    You will probably need to activate the developer tab in the excel ribbon.
    Once pasted, just go into sheet 1 and type numbers into column a.
    Private Sub Worksheet_Change(ByVal Target As Range)
    cur_cell_row = ActiveCell.Row
    cur_cell_col = ActiveCell.Column
    Dim KeyCells As Range
    ' The variable KeyCells contains the cells that will
    ' cause an alert when they are changed.
    Set KeyCells = Range("A1:C100000")
    If Not Application.Intersect(KeyCells, Range(Target.Address)) _
    Is Nothing Then
    End If
    Cells(cur_cell_row, cur_cell_col).Select
    End Sub
    Sub sort_a()
    ActiveWorkbook.Worksheets("Sheet1").Sort.SortFields.Add Key:=Range("A1"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortTextAsNumbers
    With ActiveWorkbook.Worksheets("Sheet1").Sort
    .SetRange Range("A2:D100")
    .Header = xlNo
    .MatchCase = False
    .Orientation = xlTopToBottom
    .SortMethod = xlPinYin
    End With
    End Sub
    Do I win the prize :):)
    FordDude likes this.
  5. FordDude
    What I started with was merging cells (bcd) (efg) and (hi). So when I do the filter thing it is giving me a raspberry and saying the cells need to be the same size. So I started over and dragged the cells to make them longer. It does work now, but I will have to highlight the whole page to get them in order. This company is adding stores, and I wanted to add at the bottom hit enter and have it find its place. This will work for now. Thanks...
  6. FordDude
    We are all winners here at the Fix. I will give it a try. Tanks
  7. RapidRabbit
    RapidRabbit Well-Known Member
    Wait, there was question in there.
    Column A , hot red head?
    Did I get it right?
    tarafied1 likes this.
  8. tarafied1
    tarafied1 Well-Known Member
    I don't know what mumbo jumbo they are rambling about but but I scrolled down to see if there was more pics and there was all this weird typing stuff...
  9. msell66
    That shit's out of my league!
  10. 6t6red
    6t6red Well-Known Member
    Damn geeks. Im to old for that stuff.
  11. scedd
    scedd Well-Known Member
    Can we have more pictures instead?
  12. janschutz
    janschutz Corn Hauler
    oh wait, that is what I do for a living.
  13. Midlife
    What is an Excel?
    All I know is that I would love to spread her sheets...
    tarafied1, RapidRabbit and 6t6red like this.
  14. 6t6red
    I havent laughed this hard for along time.
  15. Horseplay
    Horseplay Well-Known Member
    Just post up more pics of the girl already!
    RapidRabbit likes this.
  16. msell66
    Dammit, Tim's pic is not showing up on mobile app.
  17. tarafied1
    just a playboy bunny, looks like this
  18. FordDude
    Worked on my cell phone, but the tank did not.
  19. Gigantopithecus
    Gigantopithecus Well-Known Member
    Hell, I'm a geek by trade and that crap is over my head.
    Sent from my HTC One using Tapatalk
    6t6red likes this.
  20. StangFix
    StangFix Member Staff Member Administrator
    did this get solved?
