So the girlfriend and I recently moved into a new (to us) apartment in an older building. The tub has started slowing down so I figure there's a hair blob down there. I try all my usual techniques and find the drain to be relatively clean up top, clog has to be further in than I am used to. So I try the old plunger with a wet rag on the overflow vent and a bunch of crud comes up but nothing that would cause a clog. Problem is, now the tub won't drain at all. I guess I moved the clog, but in the wrong direction. So now I try the trusty snake but I can't get it to move past where the p trap should be. I'm at a loss as to what to do. I know this should be a relatively easy fix, but I've been getting no where for the last 3 hours. Any ideas what I can do to get the snake around the p trap. its just a 1/4" 15' long snake. Should fit fine. I'm wondering if the drain has a different setup than usual. For example our toilet is a rear exit because our building has concrete floors and all the plumbing is in the walls. Would there be something similar for a tub that could be my problem? Thanks for any help.
