Or people with experience converting attic spaces.
Opinions welcome! I'm involved in a project that is converting an existing attic space into a third floor master suite (Why anyone would want a third floor bedroom is beyond me). Anyway, the existing structure because it was an attic, has two by six floor joists. I've questioned the builder on integrity of the supporting structure. The tub alone full of water will weigh close to 500 lbs. sitting on 2x6's that span 14 feet. I envision this thing crashing down to the bedroom below.
Couple that with a few of the joists not under the tub getting a 2-9/16" hole drilled through. What possible strength could remain?
Naturally there are other penetrations through the lumber (electrical wiring, alarm, water lines, etc...).
The builder doesn't want to follow my advice. Which is pull back all wiring, etc... Sister in a minimum of 2x8 preferably 2x10"s by nailing them to the existing 2x6 from baring point to baring point. He prefers to leave the 2x6" saying they are strong enough. he says he will "compromise" by putting 2x4s on top of the 2x6"s screwing down through them joining them together every foot. Effectively making a 2x9. Where any future penetrations will be the lumber will get gusseted together with plywood.
Is this a strong enough way of doing something? I may just bid this job high enough not to get it.
