FORSALE ARP oil pan stud kit for 289/302/351W/351C
Discussion in 'Classifieds (Mustang)' started by Mach1Mark, Feb 8, 2015.
  1. Mach1Mark
    Bought this kit for my engine build and found out the studs are too short for my cast aluminum pan. I have the original packaging card and they have been screwed into my block but not torqued. Paid $60 from Jegs. Make offer + shipping. p/n 254-1901 , hex head. Put the best on your engine !!
  2. Mach1Mark
  3. msell66
    msell66 Burning Fossil Fuels as Fast as Possible Donator
    I don’t need them, but I do like them! They make it so much easier to install the oil pan.
  4. David67
    David67 Active Member
    Out of curiosity which kit did you use?
    Sent from my Pixel XL using Tapatalk
  5. msell66
    Honestly don’t remember other than it was an ARP set. Short studs too.
  6. David67
    Do you think it would work with a stock oil pan?
  7. msell66
    Just looked at this set Mark is selling. Sure looks like it would work with a steel pan. My Canton pan uses the short studs.
  8. Mach1Mark
    Absolutely they will fit a stock pan !! I installed a cast aluminum T-pan and the clear distance between the bolt hole and the outside of the pan is very close. I ended up using grade 8 hex head bolts and small diameter washers.
    msell66 likes this.
  9. Mach1Mark
    Thanks, Mark !!
  10. c6fastback
    c6fastback Member
    Used the same on my Cobra oil pan .
