Ponyman66
Yak, yak, yak
Okay, I give up! When I purchased my Unisteer R&P I ordered it with a serpentine pulley. When it came in the serpentine pulley was provided, but the standard V belt pulley was on the pump. It's a Gen II TC pump (GM), but the custom billet pulleys don't have the usual neck on them to allow them to be pulled with the standard p/s pulley removal tool. I've resorted to trying a three finger puller through the holes in the pulley to allow pressure on the central part of the pulley hub. Due to their pattern it won't allow a straight pull (I threaded a bolt into the pump shaft to put pressure against to prevent pump or pump shaft damage). Due to the puller not allowed to pull straight up the pulley is getting uneven pressure causing it to bind and not move.
Yeah, in a fit of frustration I tried a large three finger puller on the outside flanges of the pulley. No, it didn't bend the pulley (they're pretty stout billet). Instead it pulled a chunk out of it. Scratch one pulley! Lesson? Frustration usually results in dumb ass move! :roul
Fortunately I did not intend to use the pulley. I had intended to offer to someone that wanted it....not an option now! Due to my work schedule it's difficult for me to call Unisteer's tech folks until next week. Just checking to see if anyone could offer suggestions or had any experience with these pumps/pulleys.
