FORSALE Bunch of NOS parts & couple of OEM
dbenichou289
New Member
I thought I would offer these up to my friends on StangFix. Prices are negotiable, just be fair. Just add shipping. Please reply or PM me for detailed pictures of any parts you are interested in. Thx
386056-S2 carb air cleaner studs pk of 4 $10
C2DZ-10718-C battery hold down clamp 2 available 65-66 $15 ea
C4AZ-2004-A M/C repair kit $30
C5AZ-12370-R (DD-190) Diaphragm dist vacuum $125
C5AZ-9155B fuel filter $10
C5ZZ-1130-W red wheel hub center caps qty 3 65-67 $55 ea
C5ZZ-1012-B Chrome wheel lug nuts set of 5 $20
C5ZZ-17A553-D 2-speed switch (C4ZB-17A553D) $50
C5ZZ-2282A brake hose $10
C5ZZ-7262-A 65-68 shifter bezel – 4 speed (C4ZB-7262-B) $250
C8GY-5443505-A trunk lock cylinder with keys $40
C9ZZ-7591-A Spring, clutch return 69-73 $10
D0AZ-18599-A manifold elbow 390, 351C 69-73 $30
D1AZ-14413-A glove box light kit 71-74 ford, 73-78 Torino $20
D3TZ-13853-A relay, horn 65-69 $45
D3ZZ-2251-A wheel cylinder $10
D9BZ-7052-A oil seal, transmission, ‘70s and ‘80s $10
DOZZ-17A553-B 2 speed wiper switch (D0ZB-17A553-A) $100
FILCO 3360LC ignition switch with keys (vintage) $10
C3AZ-17528-J wiper blades assy pk of 2 $75
D5DZ-3020-B front suspension bumper pk of 2 $10
C8ZZ-16098-A emblem mustang script 68 specific $45
C5ZZ-2457-E Power brake pad 2 available 65-67 $20 ea
C8TZ-9722454-A door handle button kit 65-68 4 sets available $45 ea
C1AZ-17664-C pump assembly washer 65 only $100
C5AZ-17664-A pump assembly washer 66-68 $150
D1AZ-6523352-K Knob, window crank black $15
D3AZ-15052-B Knob and cig element 65-69 2 available $30 ea
E0VY-15055-A cig socket and retainer 65-69 $20
D3AZ-15054-B cig element only $10
C4AZ-62103A58-D quarter panel drain valve 65-73 $20
C8DY-5448505-A trunk lock cylinder with keys 69-71 $40
D0ZZ-8213-A Tri-bar horse grille ornament 1970 only $150
C7ZZ-13A355-B hood turn signal lamp assy 67-68 $40
C4ZB-16098-C mustang emblem 64-1/2, early 65 specific $60
C20A-7A531-B pivot, clutch equalizer bar 65-70 $20
C30Z-7513-A clutch fork dust shield 65-66 6-cyl $25
C0DZ-2760-B E-brake handle 65-66 $20
C5ZZ-15520-C Switch and bracket, back up lights 65-66 $30
B7AZ-2078-A 64-1/2,early 65 brake hose assy B4 8/64 (2 ava) $15 ea
C5ZZ-65290A76-A Quarter panel ornament 65 $45
C9ZZ-15514-B lens clear 69-70 back up light $20
C50Z-6221984-A lock cylinder w/key 65-66 2 available $15 each
C4DZ-15663-A convertible top switch 65-66 $60
D2ZZ-15520-A switch, 3 speed back up light 72-73 $35
C9ZZ-19B888-A A/C vacuum controller valve 69-73 $120
D1ZZ-6540282-series M.U.S.T.A.N.G. trunk letters 71-73 full set $75
383465-S100 6 bumper bolts –with proper shallow convex $80
C5ZZ-16763-B Hood bumpers 4 boxes, 2 in each box $80
C7AZ-16606-A,B,C,D F.O.R.D hood letters $80
C40B-13A408-A plug wire tail light 2 available $10 ea
C5ZZ-7535-A Clutch bracket $30
C5ZZ-7A533-A Boot, clutch rod to firewall $35
C3DZ-3A717-A & C3DZ-3A714-A P/S hoses PAIR $55
USED- OEM items
Rear 65-66 quarter panel fender skirts – OEM by Fox Craft $200
COBRA open letter valve covers by ANSEN $500
Updated list...
C8GY-5448505-A trunk lock cylinder with keys 69-71 $40
C5ZZ-16763-B Hood bumpers 2 boxes, 2 in each box $40
USED- OEM items
