RagTop
Old Grumpy
I've got a 69 302 with a 625 cfm Road Demon, Edelbrock Performer, a 351W cam (single profile, .224 duration, .500 lift), GT40P heads and Motorsport roller rockers. The darn thing doesn't want to idle in gear. It's got a pretty bumpy idle, which I love, and it will idle normally in neutral, but as soon as I put it into drive it starts to lope harder and then just dies. I've tried raising the idle to no avail. I took the car to a guy who did wonders with my 69 Vette's 750 cfm Rochester Quadrajet and he actually made the problem worse. He said he didn't like Demons and I should have listened and gone somewhere else. He left the front float level screw so loose that it was flooding my intake manifold. I tightened it down after adjusting both float levels to midway on the large sight glasses on the Demon. The strange thing is that the problem comes and goes. It'll start fine, but by the time I get to the stop sign about a quarter mile from the house, it will stumble and die if I don't slip it into neutral. After it's been running for a while it will idle fine in gear at stoplights. It's still bumpy but that's part of the joy of having a performance cam. If I stop and let it set for a half hour or more, it will be hard to start and will start dying under any load like the power steering to turn out of a parking place. It'll die several times before I can get it going again. I've noticed that, if I drive with two feet at those times and feed it more fuel, it will keep running, but that is a dangerous practice. It makes hitting something or someone a little more possible. Any ideas what might be wrong with this thing? It never used to be a problem.
