68angrypony
Hello all.
I have a 68 mustang with a 351c. It has all the original wiring in it and the original voltage regulator from the looks of it. The problem I'm having is that with everything hooked up under the hood if I turn the ignition to start the car it will just keep power going to the starter. It won't stop cranking when I let go of the key. I have a new key assembly with ignition switch in their. I have no idea why it is doing this but it would be great if someone can guide me in trying to figure out what is going on. To start the engine I have been putting the coil wire to the battery positive and running a wire from my starter to the starter solenoid on the fender. Anyone have any ideas how i can get the car to start with the key?
Thank you,
Jeremy
Thank you,
Jeremy
