Correct fuse size for Cigar Lighter/Emergency Flasher? 20A won't fit is manual wrong?
1965GTFB
On early San Jose '67
Factory manual shows SFE 20A fuse but it will not fit, too long. That slot on the fuse box is marked 20A.
Interesting thing is the same manual on the facing page has the diagram for the Cougar fuse box. It shows the box marked as 20A but in the use description, Cig./Emerg. it says 14A with an arrow pointing to that slot.
Is there such a thing as an SFE 20a fuse that is shorter. All the ones I have are about 1.175". Called the local NAPA and theirs all are at least that long.
Error in manual? Should it really be a shorter 14A?
