Hey guys, I figured I'd post a thread showing this particular kit I ordered and what is involved in installing it on a small block Ford. I'll be offering my opinions as I go.
This is what I ordered:
https://www.cvfracing.com/Serpentine-System-for-Ford-289-302-351W-AC-Only-p/302-wraptor-aco.htm
My options were: short pump and 4 bolt aftermarket balancer.
The full kit comes in one large, heavy (~65 lbs) box. Be prepared to handle that. I unwrapped and opened everything and this is the full kit fresh out of the box:
20180227_171316 by Brett, on Flickr
The instructions are not as glorious or detailed as some of the other companies I looked at that offered instructions online. They're basic, but I'm sure they'll get the job done. They are missing some information I noticed, though.
The Alternator:
I'm not sure if this is a Poweremaster alternator or another brand. It comes with a stamped steel fan and pulley. The kit comes with a new fan and pulley in a separate box. I would've thought that would already be installed, but no worries, an electric impact swapped them out super quick. One thing that was lacking in the instructions is a torque spec. Which wouldn't be needed should this pulley already come installed. I googled it and found a Powermaster article that said they torque theirs to 70 ft/lbs.
20180227_180036 by Brett, on Flickr
Water Pump (short):
The instructions state that the kit only includes bolts for the spots were the bracket mounts on the timing cover/ water pump. Seems a bit incomplete to me. Especially since the kit includes a new water pump.
The kit only provides the bolts 4 spots on the timing cover. You will still need the top 3 bolts on the water pump and the lowest 4 on the timing cover. I have ARP bolts on my other cover, they should fit on this no problem. I also need a timing pointer. Looks like the 10 or 11 o'clock ones will work without issue.
20180227_190139 by Brett, on Flickr
There are 2 different directions to install the water pump. The main instructions say to use blue RTV or similar where the water pump came with it's own set. I am going to try and use the ones in the water pump box. They say not to use silicone, but rather a "contact glue for countertops". I'll need to pick some of that up from Home Depot.
TO BE CONTINUED!
20180227_171316 by Brett, on FlickrThe instructions are not as glorious or detailed as some of the other companies I looked at that offered instructions online. They're basic, but I'm sure they'll get the job done. They are missing some information I noticed, though.
The Alternator:
20180227_180036 by Brett, on FlickrWater Pump (short):
20180227_190139 by Brett, on FlickrThere are 2 different directions to install the water pump. The main instructions say to use blue RTV or similar where the water pump came with it's own set. I am going to try and use the ones in the water pump box. They say not to use silicone, but rather a "contact glue for countertops". I'll need to pick some of that up from Home Depot.
TO BE CONTINUED!
20180302_220856
20180302_184919
20180302_215601
20180303_123126
20180303_142805
20180303_142823
20180307_185854
20180307_185834
