buckeyedemon
if your problem is a little bit of resistance causing voltage drop, then switching to a plug in led based bulb should help in itself. they draw over a magnitude less current.
"buckeyedemon" said:if your problem is a little bit of resistance causing voltage drop, then switching to a plug in led based bulb should help in itself. they draw over a magnitude less current.
"DougG69" said:Speaking of those LED bulbs... I saw on your thread on 69Stang.com where you were talking about bulb selection and thought maybe the red 18 LED bulb would have worked out the best for you. Do you still feel that way now that you've had some time with the 45s?
"buckeyedemon" said:i don't recall where i said a red 18 LED bulb would have been the best (as compared to the red 45).
"buckeyedemon" said:I did paint the buckets white (i think gloss?), have new lenses and a new tail light harness, so maybe all those things add up to nice lighting.
"jmlay" said:When painting the housing use a gloss paint as the flat or satin will not reflect as well.
"cmayna" said:What I did with Shag was to spray the inside of the shell with VHT's plate paint.
http://scoutparts.com/products/?view=product&product_id=16202
