I just found out the hard way, if you're bolting heads onto a late model 5.0, with the block whose outer head bolts penetrate the water jacket, DO NOT USE ARP THREAD SEALANT. I did, and the result is a big mess with coolant leaking from the rear bolts on both sides. Google popped up some on-line article on the SBF which advise to use Permatex No. 2. I hope they're right!
