Dyno Day for the 502
Discussion in 'Engine and Drivetrain/Mechanical' started by tarafied1, May 11, 2018.
  1. Fst Blk
    Fst Blk Well-Known Member
    Good job dad. Hurry up and get that thing done and bring it over lol.
    tarafied1 likes this.
  2. tarafied1
    tarafied1 Well-Known Member
    lol, that was supposed to be holding the heater hoses out of the way! Didn't really help!
  3. tarafied1
    it's getting really close! I got a lot done tonight
  4. tarafied1
    Still some things on the list
    [​IMG]
    [​IMG]
    Grabber70Mach and Larry G like this.
  5. Horseplay
    Gettin' close!
  6. RapidRabbit
    RapidRabbit Well-Known Member
    That's looks awesome!
  7. msell66
    msell66 Burning Fossil Fuels at c2 Donator
    It’s almost done, just a few more things. Good job Craig!!
    Mark
  8. tarafied1
    thanks guys, my check list is getting shorter.
    I need to do some wiring. I am switching the Duraspark II box to an MSD 6AL and I need to wire up the NSS and reverse lights. I need to figure out how to get the fluid in the trans! Should have done that while it was out! But I would have probably dumped it all out when I tilted the engine. I need to finish up the Tilton Hyd TO bearing setup and bleeding and pedal stop. Put the dash back in (I had it out to put in the pedals). I still need to order a drive shaft. Then I will need to have my H pipe modified since the engine has moved. Need to work out my fan/fan shroud stuff too since the engine moved. Lots of little stuff like that! But I work on it a little each night. I am leaving for England and Germany this weekend so it will be a couple weeks before I can get back at it. I'd like to get the drive shaft ordered so it's being made will I am gone.
  9. Horseplay
    Better to fill the trans installed. Less mess. I used a length of hose with the end of a small funnel cut down to fit tightly in the hose end but with the small end able to fit into the fill hole opening on the transmission. Then I simply stuck another funnel in the other end of the hose up outside the car and started to pour the fluid down to the trans. Couldn't have worked better or been easier. I knew the volume of fluid necessary to fill the trans and simply stopped adding fluid when I got that much down the hose.
  10. Horseplay
    Not sure what you are doing for a driveshaft but if you want to spend the money I can't recommend Denny's enough. Excellent service and the product is very nice.
  11. msell66
    Times 2.
    Mark
  12. Mach1 Driver
    Mach1 Driver Active Member
    in the service we used to call that a Sky Hook.
  13. tarafied1
    thanks, I emailed the form with my dimensions. We'll see how much!
  14. Patrick Stapler
    Patrick Stapler Active Member
    Late to the party...sounds healthy. Congratulations.
  15. tarafied1
    thanks! it's very close to running again!
  16. tarafied1
    Modern Driveline (Who I bought the kit from) quoted me $695 for a 4" Aluminum drive shaft good for up to 1200 hp
  17. Patrick Stapler
    Never used Denny’s. Probably good stuff though if Mark is using one. I have an aluminum shaft in my car from SorT. Nice product. Not sure how it compares in price. Right at $300 if I remember correctly.
  18. tarafied1
    I'll check with them too, didn't know they sold them. thanks
  19. Fst Blk
    I had a 40 dollar 4 inch aluminum junkyard explorer driveshaft shortened and rebuilt with new joints for 100.
  20. tarafied1
    local?
