Finally have the parts to reassemble my engine
It looks like the shaft mount rockers might have a lower profile. Do you think they would fit under stock 289 valve covers?
Robert
Did you eliminate the bypass hose from the thermostat housing to the water pump? I can understand eliminating the heater hose from the waterpump, but the bypass hose allows the water to circulate while the thermostat is closed. Blocking the bypass hose essentially prevents the water pump from pushing any water, and is really bad on the impeller (cavitation). Youtube is blocked at work, so I can't see the car with everything buttoned up.
Congrats on getting it fired up! Now get that thing back on the track!!
I'll pick up a by-pass hose and see if it makes any difference. It's one thing I'm sure that won't cause a massive failure!
Robert
If you would've asked that before I finished...........
I really don't know and since I don't have any stock VCs, can't check.
If past performance holds true, those covers will be off soon and he'll be able to take some measurements.
It could cause you pump to explode, throwing shrapnel into the timing chain and locking the motor up.
Kidding of course, but you'll probably have a shorter waterpump life with the bypass hose...uh...bypassed LOL
Ouch
If I had any feelings, you might have hurt one.
