crustycurmudgeon
At the risk of :dh, look at the following picture:
The torque convertor studs will poke through the 4 holes you see at the 1:00, 4:00, 7:00 and 10:00 positions. The two larger holes at 2:00 and 8:00 are the ones that the drain plugs should be poking through. Your flexplate may have both holes or just one and they may not necessarily be in the same position as the picture. If a drain plug isn't positioned so it pokes through the hole it will push on the backside of the flexplate and bend it outward toward the engine. If this is the case, you'll need to take off the 4 nuts holding the flexplate to the convertor and move the tranny back enough to disengage from the flexplate and turn the engine 90, 180, or 270 degrees until the drain plugs stick through the holes.
This is such a common issue that I want to be sure this isn't what you're experiencing.
Frank
Frank
