The driver side window on my currect project is quite stuck in the up position. I took off the door panel to see what was haning it up and it appears that the mechanism is in fine condition. When you crank it, you can see everything moves just a hair and then stops. The rear edge of the window has more movment than the front. It looks like the channel of the vent window has rusted and frozen the sliding glass in place. I've tried running a thin blade between the channel and the glass and I think I pulled some of the rust out of there but its still not moving. Anyone deal with an issue like this before. Suggestions or something I might be missing? Thanks a lot folks.
