Shrinkdude
Running things over in my head
I am mounting the battery and start relay in the trunk.
I am running 1ga cable to the starter from the relay
I plan to run 8 gauge from the battery side of the relay to a terminal post located where the battery was in the engine compartment.
Here is my question:
Why would I need to fuse so large (been reading posts on forums) in the trunk between battery side of relay and front terminal block/post?
Once the car starts then all power (ideally) is run from the alternator which has a 10 gauge at best, probably 12 ga.
I still have the old style not the 1 wire alternator
I was planning at a 30 amp fuse as I have a fairly stock system besides the electric fuel pump(3amp) and halogen headlights (6 amp).
Any insight would be helpful
