Hello From Cali ( Bay Area )
chris canion
New Member
Hey whats up My names Chris,
Found this forum alittle bit ago when researching ways to restore my reverse lights. for my 1970 mustang Coupe M-Code. Ive owned nothing but fords nd at some point have modded each one so far my my 1970 is going to be a complete resto mod some day..or my coffin!
Cars Owned
2000 Ford f150, V6 4.2l - Mac Shorties Custom exhaust 2.5 SS, Mac Cold Air intake, P&P Half shafted TB, Underdrive Pullies
1996 Gt Mustang Convertible 4.6 sohc - Trick flow TB/Plenum/CAI, MSD Wires and Coil, Full Cobra Brakes w/SS lines, MMEadj Lowers, Hotchkis Uppers, Cobra front arms. Balanced Ford racing drive shaft
-2nd motor 97cobra motor JLT CAI, FR alum fly wheel, MSD coils and Wires, IRMC REmoved (epoxy Mod)
1970 Mustang Coupe M-Code -351c Replace with 351w trans is orginal FMX and rear is orginal 9in 3.00 open (.30 over, 357w) Edelbrock WP, Performer intake, Fuel Pump, MSD Coil wires Ready Run Dizzy, Holley 670 cfm Street Avenger, Long Tubes headers to custom 2.5 dual exhaust. Grab-a-track suspension.
Welcome, might want to specify what transmission it came with and what it now has, some of the wiser members may be able to help you with your issue.
From Infinity and beyond
Never Argue With A Moron– They Will Drag You Down To Their Level, Then Beat You With Experience
Never messed with the FMX reverse switch, but the AOD is internal to the transmission. You will either have to take the one that's original to the car and use the end that goes on the AOD then splice together. Or buy a premade one from a vendor.
Sent from my GT-P5210 using Tapatalk
Could be as simple as a blown fuse. That fuse controls the stock radio power, backup lamps, and a portion of the wiper blade system. Check the top left fuse.
well i know i have a hacked up harness by the radio cause when i did drive the car it would be thrown sparks some time when id drive or take off.....i have a Painless kit made for my 70 thats been sitting in the passengers seat for 5 years now...only thing that keeps me from installing is having to remove it when it need paint and body work which it does need
Chris welcome to the forum. All I can say is 'fire!'....
