How-To Section
Discussion in 'Site Info' started by 68Hidalgo, May 1, 2017.
  1. 6t6red
    6t6red Well-Known Member
    no workie
  2. StangFix
    StangFix Member Staff Member Administrator
    All when you click on the link above Resources you should see this page
    Can you see the ADD RESOURCE on the right?
  3. StangFix
    Drinking heavily last night and played around on the CPU...:)
  4. Patrick Stapler
    Patrick Stapler Active Member
    Yes we, or at least I...can see the thread, but that's where it stops. There is a message at the bottom of the image that says something to the affect of not having privileges to view the full content of the thread.
  5. StangFix
    @Patrick Stapler just tested it using the Test Permissions and it works
    "The permission tester allows you to view the forum with the permissions of the specified user. You will still be logged in as yourself, but your permissions will show you what is visible for this user."
  6. tarafied1
    tarafied1 Well-Known Member
    I get the same thing...
    Grabber70Mach likes this.
  7. tarafied1
    I just added a "resource" a bit confusing process that doesn't seam to work right. I just ended up putting a description in the text and a link to the original in the description as well. can you guys see it?
  8. jims6t6
    jims6t6 Well-Known Member
    I can see yours but the other two has the following
    "You do not have permission to view the full content of this resource."
  9. tarafied1
    it's a bit confusing when adding a "resource". There are places to put URL's. Maybe the links are to places we don't have permission to go?
  10. jims6t6
    I could follow your link ok.
  11. Boom
    Boom Active Member
    [​IMG]new resources by Brett, on Flickr
    Just tried a minute ago. Same thing with the brake one. I can see the turn signal one just fine though.
  12. StangFix
    Try it now, I think I have the issue Stangfixed :)
  13. Midlife
    No more issues with needing to log-in or limited ability to read the entire thread from here.
  14. msell66
    Why does it still show that I need to log in again? I’m already logged in.
  15. Midlife
    Mark: clear your browser cache and try it again.
  16. Boom
    Boom Active Member
    Seems to be working now. Thanks for fixing it so quickly.
  17. msell66
    Using Tapatalk. No option that I’ve found to clear its cache.
  18. Fst Blk
    Fst Blk Well-Known Member
    Took me deleting the app to get logged back in with Tapatalk. Pita
