One_fast67
I am getting ready to weld the mounting brackets for the interior quarter trim panels to the rear floors but i have misplaced the dimensions of where they go. Anyone know the dimensions of where these get mounted?
"cmayna" said:My only suggestion is to just tack the brackets in and do a seat fit test. Meaning install the rear interior quarter panels, measure the distance between the two panels. Measure the width of the seat. The worst thing you can do is to weld those brackets in too far inward not allowing the rear seat to fold down. Keep in mind, the tolerance is that little narrow shelf which the seat lays down onto.
Yes that is what I meant. Yes, better to favor wider distance and shim as necessary."stangg" said:+1... but go one step further and install the folddown curved panel to insure the panels don't scrape the side of the panels. This is what I did when I converted from coupe to fastback... Also, Better to go favor a wider distance between the bottom braces and shim between the panel and bracket if you need to tuck it in some.
edit... I meant the fold down curved panel... Not sure if that what craig was inferring.
"GTchris" said:2-1/2"
7-1/8"
6-3/4"
