Modified 1968 Coupe
Discussion in 'Member's Build Threads' started by GPR, Mar 10, 2011.
  1. GPR
    GPR Active Member
    Because of working on customers cars I don't have a lot of time to work on my projects but we have gotten a few things done.
    My son Brian, Steve Baur (former Modified Mustangs & Fords editor) and Buddy installing a Ron Morris EFI fuel pump and lines for a story that was featured in the magazine.
    [​IMG]
    [​IMG]
    StangFix likes this.
  2. Midlife
    The dog seems somewhat dis-interested...but is a great picture nonetheless!
    tarafied1 likes this.
  3. Grabber70Mach
    Looking good, that is going to be a really great looking car when you get it finished.
    From Infinity and beyond
  4. GPR
    GPR Active Member
    The fuel lines and filter are attached to the subframe connector
    [​IMG]
    [​IMG]
    They go through the torque box and into the engine compartment
    [​IMG]
  5. RapidRabbit
    RapidRabbit Well-Known Member
    What kind of fuel lines are you using?
  6. RapidRabbit
    Thanks. In trying to get my efi done and that looks easier to work with.
  7. RapidRabbit
  8. kb3
    kb3 Well-Known Member
  9. RapidRabbit
    I have ordered a lot of my efi stuff from him and my aod crossmber.
  10. GPR
    GPR Active Member
    I forgot to show this but awhile back Mark Houlahan came by the shop to help us install the Ron Francis wiring harness for the SOHC Mod motor.
    [​IMG]
    [​IMG]
    We are not finished under the hood
    [​IMG]
    Brian was helping Mark
    [​IMG]
    Takes a lot of wires to run a modern engine
    [​IMG]
    [​IMG]
    Every wire is numbered so you can't make a mistake if you hook it up to the same number on the control panel that is plugged into the stock Ford computer.
    RapidRabbit and Grabber70Mach like this.
  11. RapidRabbit
    Looking good. Can't wait to see this one finished up. Should be a sweet ride.
  12. janschutz
    janschutz Corn Hauler
    Wow, That is one reason I hate to do wiring. A lot of wires for me to make a mistake.
  13. Midlife
    John: it's people like you that I like!
    BTW, when one goes aftermarket for wiring, it is a must to have the car in hand to measure and install the wiring. I get a lot of requests for extensive modifications to stock harnesses, but without the car available to measure and fit things to make them nice and neat, I have to decline that type of business.
  14. JRANGER
    JRANGER Active Member
    Really cool build
  15. GPR
    GPR Active Member
    Brian and I were trying to figure out what we were going to do to cover up all the wires in the trunk and we found out about Mustang to Fear's trunk kit for the coupe. At the time we inquired they only had one made for the Eleanor style taillights. Rich said he was going to make one for the stock taillights and we also received the first gas filler neck cover.
    [​IMG]
    [​IMG]
    We still have to make a bracket to mount the computer and control panel behind the the Mustang to Fear trunk panel kit.
    You can read all about the install How to Finish Off Your 1967-1968 Mustang?s Trunk
  16. Fast68back
    Fast68back Well-Known Member Staff Member Moderator
    Damn it, now I have to look into one of those trunk kits for my car.... The car looks great
  17. GPR
    GPR Active Member
    I decided to mount the wiring behind the seat on the plywood board that came with the Mustangs to Fear trunk kit.
    [​IMG]
    I replaced the coil packs and plug wires but still have a lot to do under the hood.
    [​IMG]
    Grabber70Mach likes this.
  18. GPR
    GPR Active Member
    We installed the Dakota Digital gauges awhile back but I never did get a photo. Now I need to get a battery installed in the trunk so I can see them in color!
  19. tarafied1
    tarafied1 Well-Known Member
    Is that a pre-99 engine? It doesn't have the coil on plug set-up. The 99 and later had PI heads which were supposed to be better. The coil-on-plug set-up would be more tidy too I would think. It looks great, I am not nit picking, just curious
