my 66 restomod begins
Discussion in 'Member's Build Threads' started by steveh326, Sep 11, 2014.
  1. steveh326
    steveh326 Active Member
    thanks!
    pm sent... I like the 3/4 view like you have for yours, also like I am using for my profile pic.
  2. steveh326
    stopped by upholstery shop this morning, got on the list for new top. struggled between glass window and plastic, in the end I went with plastic. 2 weeks out on work so now I gotta wait... arg.
  3. steveh326
    2nd alignment done, TIRES DON'T RUB... YEAH! picked it up and drove it maybe 15 miles today... had a squeak think I got that, has a rattle in the front end I need to track that down, but otherwise seems to be doing OK, so far so good. May take a longer trip tomorrow up the interstate to calibrate the speedo and do a little more shake down.
    top is scheduled for Oct 15 or so, after that I can finish adjusting the windows, then get the door panels installed.
  4. Grabber70Mach
    Congrats glad to hear that you got the rubbing issue resolved.
    _____________________________
    Never argue with a Moron. They'll just drag you down to their level and beat you with experience.
  5. steveh326
    upholstery shop called this morning, top should be in 1st of next week, I am on their list for probably Thursday to get it installed... woohoo... once that is done I can final align the windows, then get the door panels on. still a couple odds and ends, and a couple gremlins I am chasing down. electronic speedo is acting wonky and won't calibrate, not sure whats up with that yet. Fitech is still learning and hopefully sorting itself out. got a clunk in the right side front end need to try to chase that down. otherwise seems to be doing fairly well.
    RapidRabbit and Grabber70Mach like this.
  6. 3175375
    3175375 Well-Known Member
    What brand of top did you get? My experience is Robbins brand is top dog.
  7. steveh326
    i think it may be Robbins but not 100% sure. the upholstery shop ordered it. He said what brand he likes to use but I can't remember. I know it's not Kee. I had him order it in the sun cloth instead of the stock vinyl.
  8. steveh326
    upholstery shop called, they got the top done early. very pleased with it. I love the cloth instead of the vinyl. they were also able to fix a couple issues I had with my back seat cover that apparently the first shop messed up. the left rear window regulator decided to crap out today so now I need to pull back seat back out and replace that... arg.
    Grabber70Mach likes this.
  9. RapidRabbit
    RapidRabbit Well-Known Member
    That looks great.
    I need to get my top done soon. It's pretty bad, but I never put it up anyway.
  10. kb3
    kb3 Well-Known Member
    I really like the looks of cloth tops over vinyl!
  11. steveh326
    thanks, me too. since I wasn't doing a restoration I figured I had free reign.
  12. blu67
    blu67 Well-Known Member
    Love it!
  13. steveh326
    finally figured out my issue with getting the windows adjusted... friend of mine and a friend of his who was an old body man worked on it the other night and figured out the issue. ended up being the window stop that's on the top of the door handle side keeping everything from adjusting properly. not 100% there yet (got to be too late) but very close. Also have a noise over bumps on the right front. jacked the wheel up and was able to rock it top to bottom like the wheel bearing was bad (it's new) so I figured I just missed tightening it up enough... but that wasn't it.... tracked down the play to the lower ball joint for some reason but have not been able to investigate further... I did check it and it's tight, so thinking maybe the new ball joint is bad or something. I may end up replacing the lower ball joint to see if that fixes it.
  14. steveh326
    discovered a clearance issue on my headers and steering linkage. at full lock left or right making contact with the header tubes. not horrible on passenger side, I think a small strategic clearance dent in the header tube will resolve it... much worse contact on the driver side. not sure yet how I will solution. so far the only options I can think of are 1) don't turn the wheel full left or right, 2) put a bigger dent in the left side header for clearance, 3) fab up some kind of steering 'stop' to limit movement, 4) find some shorty headers that might clear everything.
    on an old bobber that a buddy and I built a few years ago, we welded on a piece of chain to act as a steering stop on the girder front end ... that worked great on that bike but probably a little crude for the mustang...lol.
  15. Horseplay
    Show pics of that clearance issue. Never ran into such on any mustang I've had. The turning radius is big enough on the car without limiting it. I'd try to find a way to avoid doing that.
  16. steveh326
    it'll take me a bit to get a pic I took the car to my dad's house for winter storage since he has more room. remember I have a Borgeson box, so that may be the difference... not sure, maybe there is a little more turning radius with it over stock. the Borgeson feels great but wondering if I should have sprung for an r&p setup…
  17. Horseplay
    I have a Borgeson too. I changed the pressure output of the pump for it to lessen the assist and think its great. IMHO I don't think a rack has anything on this set-up although many could be considered worse as they limit the turning radius.
    Curious to see where the interference lies as there are possible ways to make changes that wouldn't require breaking out the ball peen.
  18. steveh326
    easiest thing is probably to find a set of headers that clear properly... but my wife is prolly gonna castrate me if I don't stop spending $ on this car soon... million dollar mustang...lol.
    what headers are you running?
  19. Horseplay
    Hedman Elites right now but their basic set fit too. I wouldn't spend any money just yet. Denting a tube isn't the end of the world and won't really affect the power of your engine.
