My 67 fastback build
yeah, I actually considered putting 65/66 parking lights in the factory-ish location and use the holes for brake cooling ducts (like the 65 GT350R)
Something like this I thought would work. Not a fan of the red, but I think it would have to be to be legal as turn signals.
Got any side shots of your car after paint that shows how the lower nose wraps over the fenders?
As promised the decklid.
You think it doesn't fit good now, you should have seen it when I started. I can work with it the way it is.
As far as the front nose, mine wasn't designed to wrap over the fenders.
I'll probably end up cutting this edge off so it can.
Sent from my SM-G900V using Tapatalk
that trunk doesn't look too bad now.
And i see what you mean on the lower nose. Mine did not have a lip. It is basically just the thickness of the fiberglass in that area. That one looks like it was designed to cut the fenders off at that point. I think you can make it like mine though
here is a pic from when the bodyshop repaired it after the accident. Not the best angle but I think you can see the edge a little bit
I was about to ask you if you had some pics lol. Awesome. Looks like just need to trim that edge flush. I'll modify the fiberglass to fit. Not the car.
No. It's a no name. I bought it along with the decklid and end caps for 500 bux. Fit leaves alot to be desired but for 500 bux I can make it work.
