My new old truck
Discussion in 'Non Mustang General Discussion' started by Fst Blk, May 12, 2016.
  1. 3175375
    3175375 Well-Known Member
    if you are having rust / leak issues, cut the roof off and make it a vert.
  2. Fst Blk
    Fst Blk Well-Known Member
    I'll fix it. No stranger to rust. Remember I'm restoring a mustang lol.
  3. tarafied1
    tarafied1 Well-Known Member
    okay, I just did another inspection. I guess there is sealant in there it is just painted over. I suppose I will need to scrape it out and re do it. here is a pic of the holes inside the cab
  4. KBMWRS
    KBMWRS What did the moron say today?
    simple .....paint it again. I knew I could help.:rolleyes:
    tarafied1 likes this.
  5. stangg
    stangg Active Member
    I thought there would be... I had to re-do it on my '65 El Camino. Used a propane torch to soften the seam sealer then pick it out with various pics and small screw drivers. You can put traditional seam sealer back, but most recommend using a two part self leveling sealer in the gutters.
  6. Fst Blk
    I'm not looking forward to this repair. Dreading the bedside worse though.
  7. Fst Blk
    Been switching the 67 over to 5 lug disc in all corners. 781bc0cab2ab0f150b0696c747c74412.jpg 272d2eb682017dbbca10d0366f8c70da.jpg
    Bought some late model camaro heritage wheels for it. 18 inch steel wheels. Man they are heavy. Found out it's an open 3.73 diff.
    Grabber70Mach and 68EFIvert like this.
  8. 3175375
  9. tarafied1
    nice work son!
  10. Grabber70Mach
    Looking good.
  11. Fst Blk
    4 wheel disc brakes and installed 2 inch lowering blocks out back. Need to hook up the brake hoses tomorrow.
    Broke the drain petcock off the radiator... it was seeping anyway. Buddy suppose to have a 4 core for 25 bux. Gonna pick it up tomorrow. Gotta change the pan gasket on the trans as it leaking like a seeve tomorrow also. Then she's ready to roll.
  12. Fst Blk
    msell66 likes this.
  13. tarafied1
    did you cut the front springs?
  14. Fst Blk
    Yeah. About a coil in a half. Plan to buy new springs and shocks for all 4 corners one day.
  15. tarafied1
    so 1 and half coil cut up front and 2" blocks in rear? That looks pretty good. I took my 72 to a show/cruise-in and overheard some guys asking each other if mine was 4 wheel drive. LOL. All the other C10's were slammed so it does look lifted next to one of those but it's all stock
  16. Fst Blk
    Yeah but those low profile tires makes it look a lot lower so...
  17. tarafied1
    true, but mine does sit kinda tall
  18. Fst Blk
    You got leafs or coils out back?
  19. tarafied1
    coils
  20. Fst Blk
    I bought cpp lowering blocks off eBay for it. They are a booger to get the old stuff off but your a little more intuitive than I am lol.
