Need a Mild 351w Recipe
82firebird
New Member
Hey guys, we're getting ready to think about the motor for my wife's 68 fastback. We are starting with a F4TE 351W. The motor will be backed by a T-5. We will be running a carb. We haven't gotten to the rear-end yet but we will be running a 9", open to suggestions on gearing.
The goals for the motor are: Street Manners! This car will be driven on the street 100%, mostly interstate driving, but will also be tooled around town. 325-375HP, I don't need a 500HP super-engine, just something we can drive and enjoy. I would like to utilize the stock heads or GT40 heads if possible. I'd love to hear your opinions.
Will this work? http://www.mustangsteve.com/351W_Parts.html
Parts list for 400 hp 351W
HOW MUCH DOES ALL THAT STUFF COST?
Plan on about $5,000 plus the labor to assemble and install it
Back to MustangSteve's HOME PAGE
INDUCTION & FUEL
WEIAND STEALTH INTAKE MANIFOLD, PORT MATCHED
CARTER #M-6904 MECHANICAL FUEL PUMP
HOLLEY 700CFM DOUBLE PUMPER CARB
COBRA OVAL ALUMINUM AIR CLEANER
BLOCK, CRANK, PISTONS AND RODS
1969 351 WINDSOR BLOCK 4.030" BORE
STOCK 1969 CRANK, .010/.010 3.500" STROKE
1992 TRUCK RODS, RWORKED, STD
ARP #150-6004 ROD BOLTS
CLEVITE 77 MAIN BEARINGS
CLEVITE 77 ROD BEARINGS
TRW L-2446-F FORGED PISTONS +.030"
HASTINGS MOLY RINGS
MACHINE WORK - BALANCE ASSY, FLYCUT PISTONS
LUBRICATION
ARP #154-7901 OIL PUMP DRIVE SHAFT
COBRA ALUMINUM OIL PAN #A6675E
MELLING M83HV HIGH VOLUME OIL PUMP
EXHAUST
HEDDMAN #88660-6 HEADERS (LONG) jet coated
CAMSHAFT
COMPETITION CAMS 1331-16 MAGNUM ROLLER ROCKER ARMS
CRANE #44306-1 RETROFIT ROLLER LIFTER KIT
CRANE #44630-16 RETROFIT PUSH RODS
CRANE #449631 RETROFIT ROLLER CAM 282/290 220/228/.542/.563 112LC
EDELBROCK DOUBLE ROLLER TIMING CHAIN #EDL-7820
HEADS
EDELBROCK #6025 1.90/1.60 PERFORMER RPM ALUMINUM HEADS
ARP #154-3603 HEAD BOLTS
FEL PRO #1011-1 HEAD GASKETS QTY 2
MISCELLANEOUS
ARP STAINLESS STEEL 6 POINT ENGINE BOLT KIT
FEL PRO GASKET SET (LESS HEADS/REAR MAIN)
FORD D2AZ6379B FLYWHEEL NOLTS (FOR FLEXPLATES) QTY 6
FLEXPLATE 157 tooth
SUM-163594 BALANCER TIMING TAPE
COOLING
MILDON ALUMINUM WATER PUMP
STANT THERMOSTAT #0-33342-05410 (180)
IGNITION
MSD BILLET ELECTRONIC DISTRIBUTOR
MSD -6A IGNITION
MALLORY PROMASTER COIL
FORD MOTORSPORT DISTRIBUTOR GEAR #M-12390-F
TAYLOR BLACK IGNITION WIRES W/ 115 DEGREE BOOTS
Set of 170 trickflow heads, vic jr intake, and a custom cam will net you some low 11 sec. timeslips.
Bill
"82firebird" said:
We are starting with a F4TE 351W.... I would like to utilize the stock heads or GT40 heads if possible.
I think it's already a roller cam block, should be able to tell with the intake off. For the street you want low end power/torque so stock heads or GT40's should be okay. The roller 351 truck cam duration is 256/266 (int/exh) advertised, I don't know the spec @ .050". Lift with 1.7 rockers is .449 intake and .476 exhaust. With 1.6's it's .422/.448. It's pretty mild but should be a pretty good street cam. (Got those specs from a truck forum). It just won't make much power or breath above about 5K rpm's.
The F4TE block is "roller ready" - but not all came with roller cams. If it didn't all you need to go roller is the lifters, cam, compatible distributor gear, dog bones, spider, and to tap two holes in the block valley for the spider. The block already has the lengthened lifter bores so it does not require conversion lifters.
With the mild goals stated I don't think you need aftermarket heads, shoot for about 9:1 compression, and the roller cam used in the 5.0HO would be a good candidate for performance and manners. Don't choke it with stock exhaust manifolds... shorties and dual exhaust with an h or x pipe.
Good luck,
-Rory
