FORSALE New T56 6 Speed
1965GTFB
New Borg-Warner T56 6 Speed.
Tag # 13-85-012
AA11379
With Bell Housing
Bell Housing # 1386-212-804A
Number on case is 13-86-065-902
Overdrive ratios are 5th=.80, 6th=.62
Comes with bell housing, clutch fork, throw-out bearing, eletronic speedometer hook-up.
Selling because going the T5 route, not building enough motor and keeping a taller rear end.
Best offer over $2,000($1,000 less then new ones on ebay right now)
Pick up in Nor Cal.
Contact Ted
707-526-0344
nelsons565@yahoo.com
Tag # 13-85-012
AA11379
With Bell Housing
Pick up in Nor Cal.
Contact Ted
707-526-0344
Bump
I googled the bell number and i couldn't find anything on it. Do you have the paperwork from when you purchased all the parts?
I checked it with both a vintage block plate and a late model(5.0 like used for T5) block plate. It fits both of those so it is for a Small Block Ford 6 bolt block. I don't have paperwork as it came out of an unfinished 67 project that I bought to use in completing my 67 project. The car had a lot of really good high end parts on it including a TCP power rack which is one of the parts I'm using. I decided not to use the new T56 since I thought it would be overkill for the 289 with mild mods and the 3.00 rear end I'm using and I already had a T5 ready to go.
