Working on the 1964 Comet and am near the end (finally). 3/4 drum brakes have fresh soft lines (front) and wheel cylinders after 30 years. I have decided that I do not like drum brakes! My hands aren't big enough to use the brake spring tool, so I used multiple screw drivers and such on all of these big-a$$ed springs and I ended up putting the first one together and taking it apart about 4 times before I got it right. Sigh.
Anyway, I am on the last rear drum (driver's side), but...the adjuster seems to be hung up. I was able to move it some initially, but now it clicks but is snapping back--it won't move the little wheel inside either direction. I can get the drum outward toward me about 3/4", but I am told that it must be grooved or it would go ahead and slide off. None of the other brakes pads/drums were grooved, so I'm skeptical. But that's not the issue. Any ideas on how to get the adjuster un-stuck?
:roulette
:roulette
