Why not put a bullet-hole emblem over it, but cut out a hole to make it look more genuine?
"Midlife" said:Why not put a bullet-hole emblem over it, but cut out a hole to make it look more genuine?
"stump" said:Talked with the shop yesterday and he's going to fill the holes and repaint the taillight panel, as necessary.
"daveSanborn" said:Nice progress Gary. Thanks for posting the picture of the trunk compartment. I never installed the slide mechanism that holds the trap door in the open position onto my FB... mostly because all of the trunk metal had been replaced and I had a new trap door so I couldn't figure out exactly where it mounted. The picture makes it crystal clear, thanks!
Where your deck lid tension rod passes through the "U" clip screwed onto the underside of the deck lid.... there should be a short length of hard rubber slid onto the rod that will prevent a possible rattle and also prevent chaffing between the rod and "U" clip/bracket.
"janschutz" said:Glad you reach a settlement. Just hopes he pays. Keep us posted. At least you have you Mustang and it is not being held hostage.
