68EFIvert
I put a Saginaw pump on my car so that the flow and pressure would match up well with my Steeroids Rack and pinion. I have a little leak on the back of the pump. There are two small holes (besides the supply and return ports) that have plastic plugs in them. I assume I need to do something to those plugs because both of then are seeping fluid. What does the back of your pumps look like? Is there bolts that go in those for mounting or should I put some other type of plug in there that would seal them better.
I thought about putting some aviation sealer on the plastic plugs and putting them back in but I fear over time the plastic would get brittle and blow out at some inconvenient time.
