Re-restoration in progress for some vintage racing
Discussion in 'The Track......' started by msell66, Jun 3, 2015.
  1. huskinhano
    huskinhano Member
    Nice man jewelry! looks like my GT40P lower end except for the block, caps, cranks, rods and bolts.
  2. msell66
    msell66 Road Worthy
    Lmao
  3. msell66
    msell66 Road Worthy
    Milled down the ends .125" and now it lines up with the head ports perfectly. Re-checked the valve lash too.
    [​IMG]
    If only I could have been here to assemble it the first time.
    Did have to go find a different set of intake gaskets. The Felpro 1250S3 DO NOT fit 289 heads! It leaves the outside edge of the water ports exposed!
    1262's
    [​IMG]
    Vs 1250S3
    [​IMG]
    Vs overlapped
    [​IMG]
  4. Horseplay
    Horseplay Well-Known Member
    if only you knew someone who could have told you the correct gasket to use in the first place. :rolleyes: Putz
  5. msell66
    msell66 Road Worthy
    That's what I get for following threads on the VMF.
  6. Midlife
    How many times have I told you not to believe everything you read on the Internet?
  7. Mach1 Driver
    Mach1 Driver Active Member
    Wait, I'm contused (sp)... you say not to believe, so should I believe??
  8. 3175375
    3175375 Well-Known Member
    I think you just use RTV
