"SAC69" said:Don't forget to remove the ground strap on the passenger side rear head.
"Kats66Pny" said:Oh yeah, I did that too! Pretty much anything that was connected to the engine/carb that would interfere I disconnected.
Something else.. if I'm leaving the trans in, do I have to drain the fluid?
Yes. They tend to leak from the speedo cable hole, the rear hole, and just about any place you can imagine."Kats66Pny" said:Oh yeah, I did that too! Pretty much anything that was connected to the engine/carb that would interfere I disconnected.
No need to drain the trans fluid, just use a plastic baggie & rubber bands to seal off the trans lines from the bottom of the radiator when/if you remove the rad. For the trans, you only need to remove the nuts (6-8?) connecting the torque converter to the engine flexplate, these are accessed thru the inspection cover at the bottom/front of the trans. Slowly spin the the engine over by hand via the crank bolt to access the converter nuts.
"Kats66Pny" said:Do I have to remove the alternator and all those damn belts from the block to pull the engine out? That looks like a pain in the butt but I see no other way to attach chains to the engine unless I remove all that stuff.
"lethal289" said:
"Kats66Pny" said:Good to know. Right now I'm leaving the rad in. I'm going to have to take it off eventually when it's time to paint the bay. I'm probably going to just replace the rad to one specifically made for 5.0 swap so the in/outs match the engine. Right now they are both on the passenger side which makes the bottom hose block access to properly hook the trans cooler lines.
LOL well I don't have to worry about the speedo cable hole. There's no speedo cable at all hooked up. PO never installed one, which I'm going to have to do if I ever want to know what speed I'm driving at!
"AzPete" said:Remove the radiator before the engine comes out. Lots more room to work. Also, I would not tear into the engine unless you have a known problem.
"Dne'" said:So, you're going to leave you tranny in~ wire it up somehow? or remove it too?
"Dne'" said:why not just do away with that B&M shifter! get a stock auto shifter and let it shift like an automatic should. I think the BM shifter looks kind of bulky myself. Unless you're going to be racing it!
